fire772
Dec 22, 2020Tutor
Ex3700 setup
I’m reinstalling the extender 3700 on a new network I’m using the same Wi-Fi name but it doesn’t seem to recognize it do I need to factory reset the 3700 on they moved installation
- Dec 22, 2020Well It looks like I did a boo-boo on the first set up.
I didn’t get something smaller to fit in the hole for the reset button it looks like it didn’t reset we got a small pen and pushed it in and did a system reset and did the WPS connection and everything works fine works fine
Dec 22, 2020Guru - Experienced User
What router are you connecting it to?
When you re-installed, did you use wps or the installation assistant?
I'd recommend factory resetting and using the installation assistant.
- fire772Dec 22, 2020Tutor
Hi
I used the wps bottoms on devices and the 2nd time did a factory reset. The old WiFi network is broadcasting so I don't think it reset correctly. Will do a factory reset again and use the installation assistant.
Using att router BGW 320
will try again
- fire772Dec 22, 2020TutorWell It looks like I did a boo-boo on the first set up.
