hal888
Oct 04, 2020Aspirant
EX3700 Wrong Gateway address, No Internet
I connected to the extender by wire or wireless and I cannot get access to the Interent. I found out the Gateway address is wrong. Updated the firmware and had not been solve the problem yet. Got...
- Oct 07, 2020
Just don't need to wire everywhere.
Got another EX3700 and it works. Contact support and those two are hardware failure. Waste my time....
Oct 06, 2020Guru - Experienced User
The EX3700 isn't designed to work with orbi. See this thread: https://community.netgear.com/t5/Orbi/Extending-Orbi-with-EX3700/m-p/1906680
some have gotten it marginally working but that was with 1. You're using multiple devices.
Plus the orbi's are designed for bandsteering. Which the EX3700 isn't.
Seems a little counterproductive to have multiple ex2700's in the same office. why not just 1 running to a switch and then connect your devices to the switch?
hal888
Oct 07, 2020Aspirant
