Netbobby's avatar
Netbobby
EX37000
Recently bought a new Wifi  Range Extender, set it up no problem at first. Now the router led goes red. Turn it off turn it on works for 5mins then goes red again.
  • plemans's avatar
    what router did you connect it to?
    Did you set it up via wps or using the installation wizard?
    what firmware is on the extender?
    • Netbobby's avatar
      Netbobby
      Linked to a Virgin Router
      Coupled us WPS
      Its brand new so assume firmware/software up to date
      • plemans's avatar
        Netbobby wrote:
        Linked to a Virgin Router---Not very specific as they have many routers. Which one?
        Coupled us WPS-----try installing with the installation wizard and not wps. wps gets coded different between manufacturers.
        Its brand new so assume firmware/software up to date-----brand new usually means it doesn't have the latest as firmware gets updated after its been made/boxed/shipped. And a number helps for anyone else with this issue.
