wwcole1
Sep 06, 2018Aspirant
EX3920 - Connected, no internet
Hello everyone, I purchased my AC750 last week. I have set it up as per the instructions say, setting up my iPhone X, Roku TV, and my Lenovo laptop. Both my TV and laptop work perfectly and I hav...
Sep 07, 2018Guru - Experienced User
Is either the laptop and TV using 5GEXT?
Can you connect the phone using 2.4 ghz?
- wwcole1Sep 07, 2018AspirantI can connect to the 2.4G, but it is the same as the 5G. Both my TV and laptop are also on the 5G.
- StephenBSep 08, 2018Guru - Experienced User
Ok. So the issue is with the iphone specifically and not the network.
I've seen a couple of other posts where folks have struggled with iOS. Unfortunately I haven't seen a good resolution - hopefully someone here who's solved this problem will chime in.
- Christian_RSep 24, 2018NETGEAR Employee Retired
Hello wwcole1,
Thank you for reaching out to the community. If you still require assistance please contact support to help resolve your issue(s): https://www.netgear.com/support/
~Christian
