Retired_Member
Jul 27, 2014EX6100 AC750 in Access Point mode - 5GHz not over 156 MBit
Cheers, I have now extended my network with two of those devices. Both share the same SSID's with the additional WNDAP360 in the 2,4 Ghz and 5 Ghz channels. They work well but I wonder why I ca...
gznoble
Aug 15, 2015Aspirant
Solution:
Log into the access point's setup using your browser (http://www.mywifiext.net is the most likely address, login and password is most likely admin and password).
Go to setup wizard. Make sure you are set to private network and not public network. Finish the setup wizard and try again. You may need to power cycle some stuff.
The AP isolation setting in some models is not listed, you simply have to make sure the device is in private network mode.
