Retired_Member
Jul 27, 2014EX6100 AC750 in Access Point mode - 5GHz not over 156 MBit
Cheers, I have now extended my network with two of those devices. Both share the same SSID's with the additional WNDAP360 in the 2,4 Ghz and 5 Ghz channels. They work well but I wonder why I ca...
damien_thg
Oct 11, 2015Aspirant
Same problem to me, in 5Ghz, my computer show a connection at 150 mbps speed instead of 450 mpbs.
I tried with an other model of my friend (other brand) in the same condition and it work at 450 mbps.
It appears there is a problem with the EX6100.
The NAT options doesn't change nothing to me.
- nhannOct 12, 2015NETGEAR Employee Retired
Hi damien_thg,
Which router is connected to the EX6100?
Is your EX6100 updated to latest firmware?
Are you using fastlane? If so, which setup?
http://kb.netgear.com/app/answers/detail/a_id/24695/~/how-to-enable-fastlane-technology-on-your-range-extender%3F- damien_thgOct 14, 2015Aspirant
Hi,
my ex6100 is connected to the box/router of my provider.
I've done the last firmware update and i don't see the same screen to use fastlane like in your link.
Regards
- nhannOct 15, 2015NETGEAR Employee Retired
Hi damien_thg,
When logged into mywifiext.net, can you please provide a screenshot of the interface you see?
Thank you
