Retired_Member
Jul 27, 2014EX6100 AC750 in Access Point mode - 5GHz not over 156 MBit
Cheers, I have now extended my network with two of those devices. Both share the same SSID's with the additional WNDAP360 in the 2,4 Ghz and 5 Ghz channels. They work well but I wonder why I ca...
damien_thg
Oct 11, 2015Aspirant
Same problem to me, in 5Ghz, my computer show a connection at 150 mbps speed instead of 450 mpbs.
I tried with an other model of my friend (other brand) in the same condition and it work at 450 mbps.
It appears there is a problem with the EX6100.
The NAT options doesn't change nothing to me.
nhann
Oct 12, 2015NETGEAR Employee Retired
Hi damien_thg,
Which router is connected to the EX6100?
Is your EX6100 updated to latest firmware?
Are you using fastlane? If so, which setup?
http://kb.netgear.com/app/answers/detail/a_id/24695/~/how-to-enable-fastlane-technology-on-your-range-extender%3F
- damien_thgOct 14, 2015Aspirant
Hi,
my ex6100 is connected to the box/router of my provider.
I've done the last firmware update and i don't see the same screen to use fastlane like in your link.
Regards
- nhannOct 15, 2015NETGEAR Employee Retired
Hi damien_thg,
When logged into mywifiext.net, can you please provide a screenshot of the interface you see?
Thank you
- damien_thgOct 17, 2015Aspirant
There she is
we can see that it is set to maximum performance. But as you can see in this other capture. The connection is not done at 450 mbps but at 150 (corner up right).
