WaltS
Aug 09, 2016Aspirant
EX6100 Access Points
I'm trying to use two EX6100s in a church with steel beams and floors. I've run two Cat 5e lines to different locations. I set the first up and it works great. But when trying to configure the secon...
- Aug 19, 2016
Hello Walts
Yea I would turn one off to set up the other one or you would have to go to your main routers attached devices page and find the IP of the second Ex6100 and use that in your web browser to get to the extenders GUI.
DarrenM
DarrenM
Aug 12, 2016Sr. NETGEAR Moderator
Hello WaltS
You may want to factory reset the second one try the setup again. Also try to adjust your wireless channel on your main router to get the best signal on the router and the extender. As for the name you can have them named the same but it could cause some issues since they are all individual wifi networks so they will not hand off the wifi signal to the best signal if you are moving around.
DarrenM
