WaltS
Aug 09, 2016Aspirant
EX6100 Access Points
I'm trying to use two EX6100s in a church with steel beams and floors. I've run two Cat 5e lines to different locations. I set the first up and it works great. But when trying to configure the secon...
- Aug 19, 2016
Hello Walts
Yea I would turn one off to set up the other one or you would have to go to your main routers attached devices page and find the IP of the second Ex6100 and use that in your web browser to get to the extenders GUI.
DarrenM
WaltS
Aug 17, 2016Aspirant
This gets me some of the way to a solution. Again, I'm using these devices as access points, NOT extenders, so the discussion regarding wireless channels does not seem relevant, or am I missing something? I'm trying resets on both devices and setting each up with the other turned off to see if I can get them working correctly.
- DarrenMAug 19, 2016Sr. NETGEAR Moderator
Hello Walts
DarrenM
