Bibone
Feb 07, 2017Follower
EX6100 and Google Pixel
I recently purchased a Google Pixel, and it is running completely stock Android. The problem I have is that the Pixel will not stay connected to my EX6100 while it acts as an extender. I have no issue enabling both the 2.4 and 5 ghz networks on the extender and having devices connect to it - in this regard, the extender is perfect. However, the Pixel is unable to hold a connection to either 2.4 or 5 ghz on the extender. I have tried the Pixel on other modems and it works flawlessly, so it must be that something is conflicting between the Pixel and the extender. I have tried changing all kinds of settings on the modem to which the extender is connected to, and have tried disabling either the 2.4 or 5 ghz network to isolate a potential issue in either speed, but nothing seems to work. I am wondering if the Pixel's software/hardware may not be 100% compatible with the EX6100.
I look forward to hearing if there are any suggested fixes or possible updates to the extender to address this.
Thank you,
Simon.
1 Reply
- DarrenMSr. NETGEAR Moderator
Hello Bibone
Do you happen to have the extender named the same ssid as your main router without the _5gext at the end of it? if so you could try to change the SSID it could be trying to connect back to your main router.
DarrenM
