jmr674
Jan 23, 2015Aspirant
EX6100 As Access Point Via POE
Hey Folks, I have an EX6100 setup as a Access Point and I have the Ethernet cable connected to a TP-Link 500Mbps POE adaptor. The other end is about 30m away at the router end where the other POE a...
fordem
Jan 23, 2015Mentor
It's not clear to me how you are using the PoE (power over Ethernet), and I'm wondering if you are in fact using PoE, or if you are confusing it with what is sometimes known as "powerline ethernet", or powerline networking
Powerline networking is a method of networking computers by "piggybacking" the data over the AC power line that powers the computers, PoE is a method of supplying power to a device using an ethernet cable.
The EX6100 plugs directly into a wall outlet, and as far as I know cannot be used with PoE - you could use powerline networking to connect it to a router, or network, and if that is in fact what you are attempting, you need to troubleshoot the powerline connection as the first step ...
Do you have internet access at the ethernet cable connecting to the first powerline adapter?
Do you have internet access at the ethernet cable connecting to the second powerline adapter?
Only when these questions can be answered with a YES, can you start to look at the EX6100 side of the connection.
