jmr674
Jan 23, 2015Aspirant
EX6100 As Access Point Via POE
Hey Folks, I have an EX6100 setup as a Access Point and I have the Ethernet cable connected to a TP-Link 500Mbps POE adaptor. The other end is about 30m away at the router end where the other POE a...
jmr674
Jan 24, 2015Aspirant
Sorry, you are quite right, I meant a POWERLINE Ethernet adaptor.
So the configuration I have is:
Netgear D6300 ADSL Modem / Router
Cat 5 Patch Cable from that into TP-Link 500Mbps Powerline adaptor.
Then 30m away I have.
Another TP-Link 500Mbps Powerline adaptor with a Cat 5 patch lead from that into the Ethernet port on the EX6100. The EX6100 has the manual switch set to ACCESS POINT and I can log into the access point via WiFi to configure same however it won't detect the Internet.
The lights on the two Powerline adaptors are showing that they are talking to one another over the power cabling.
Any ideas?
Any ideas?
