9-Ntgrcom
Aug 30, 2022Tutor
EX6100 doesn’t show connection to 2.4G network
I have a router that supports two speeds independently. The Ex6100 shows full connection status to the 5G network, it also shows the ‘extended’ network (….._2.4Ext) available for devices to connect t...
Aug 31, 2022Guru - Experienced User
Do you have a screen snip of the full status page for the extender?
9-Ntgrcom
Sep 05, 2022Tutor
seems it is showing both the 2.4g an 5g as connected.
I am not sure what happened, but all seems in order now..
thank you for your response.
also sorry for the delayed response.. your reply got sent to my junk folder and just saw it.
- plemansSep 05, 2022Guru - Experienced User
glad to see its working as it should now!
You can mark it solved so others aren't still trying to fix it.
