Xmm
Oct 20, 2015Follower
EX6100 extender - Ethernet conection
I have a problem with the ethernet conection. The extender is working properly for any wifi conection, but once I conect a TV cable box, is shows there is no signal, the lets of the wire don't blink,...
nhann
Oct 21, 2015NETGEAR Employee Retired
Hi Xmm,
Can you please clarify: are you connecting an ethernet form the EX6100 to the TV cable box, then all other WiFi connections are then lost? Which device is showing no signal?
Which TV cable box are you using?
Thank you
