seebe
Apr 14, 2016Aspirant
EX6100 EXTENDER no client light
For some reason, the extender is not connecting. The client light is not coming on. After resetting, powering off the network and starting again, hardwiring from the extender to wireless router there...
- Apr 26, 2016
I have overlooked the obvious. After moving the extender around the house a bit, both lights green. Conditions seem to have changed.
DarrenM
Apr 20, 2016Sr. NETGEAR Moderator
Hello seebe
Have you tried to connect using WPS?
DarrenM
seebe
Apr 22, 2016Aspirant
I did try that. It seems to have settled into a rhythm of having all green lights most of the time. Well, mostly.
Thanks for your suggestion
- DarrenMApr 26, 2016Sr. NETGEAR Moderator
Seebe
Has the extender connected to the router? if not have you tried to factory reset the extender and then try doing the setup with a Ethernet connected to the extender.
DarrenM
- seebeApr 26, 2016Aspirant
