steveharveysyd
Jan 16, 2017Follower
EX6100 factory reset fails
Hi, I was updating the firmware on my EX6100 which seemed to stall for an extended period. I power cycled the device and when it didn't respond, I attempted a factory reset. Unfortunately, it doesn't ...
DarrenM
Jan 18, 2017Sr. NETGEAR Moderator
Hello steveharveysyd
If you are still able to ping the device while connected to it via ethernet you may need to try and load the firmware via TFTP
DarrenM
