Retired_Member
Jun 30, 2017EX6100 is a Nightmare with Faulty Firmware
I have had the EX6100 Extender for over a year. It has NEVER worked like it should. It's the most tempermental extender I've ever had. I wish I had returned it, but it's at a vacation house, and I...
Techlore
Jul 01, 2017Apprentice
Did you contact NETGEAR at any point? There was a 1 year hardware warranty, but it sounds like you may have past that.. But if you have case numbers from before hand they might be able to help you.
Retired_Member
Jul 01, 2017No, I didn't contact Netgear because it is not a hardware issue. This is a well documented firmware problem (check how many closed threads there are). I missed the seller's (Best Buy) return window for refund. Warranty would only get me a refurb replacement....with the same faulty firmware.
http://www.tomshardware.com/answers/id-3115586/netgear-ex6100-internet-connection.html
- Retired_MemberJul 08, 2017
Anyone from Netgear care to weigh in as to why this was never addressed through a firmware update?
I've now bought two AmpedWireless extenders to replace both of the Netgear extenders I have. Installation went smoothly on both, connection is better, and signal is far stronger.
