laurafelsing
Nov 07, 2017Aspirant
EX6100 New Router
I just purchased a new Wifi router, and I can't figure out how to connect my EX6100 Wifi range extender to my new router. Whenever I go to www.mywifiext.net, it comes up with this message: "You ...
TheEther
Nov 07, 2017Guru
You need to be connected to the Wi-Fi signal broadcast by the extender in order to www.mywifiext.net to work.
If you still have trouble, then perform a factory reset of the extender. According to the manual, you'll need a paperclip. Press the button inside the little hole until the Power LED blinks amber, then release the button. Wait for the Power LED to turn solid green. Then proceed to set up the extender as if new out of the box.
- laurafelsingNov 07, 2017Aspirant
I have tried Factory Resetting the device multiple times, and it still gives me the same message when I go to either webpage.
- TheEtherNov 07, 2017GuruDid you first connect to the extender's Wi-Fi signal?
