Echidna
Sep 06, 2016Aspirant
EX6100 Not Using Extension after Network Name (SSID)
It appears that I have successfully set up the EX6100 as a 'Range Extender'. However, a device (solar inverter - 2.4GHz WiFi only) does not find the range extender's WiFi SSID with the _2GEXT. It d...
- Sep 07, 2016
Hello Echidna
You are able to rename the SSID with out it having the 2GEXT if you believe that is the issue for that device not being able to see the network.
DarrenM
DarrenM
Sep 07, 2016Sr. NETGEAR Moderator
Hello Echidna
DarrenM
- EchidnaSep 08, 2016Aspirant
Thanks DarrenM. Removing, or changing, the range finder's SSID extension didn't solve the problem. As other devices can see the range extender's 2.4 & 5GHz SSIDs, it's got to be an issue with the inverter's WiFi setup.
Thank's again for your advice. It was worth the experiment
