Ensa53
Dec 03, 2016Aspirant
EX6100 takes down BT Hub 5
I have been using the Extender to provide internet access to my smart TV via ethernet cable and also to extend WiFi signal into the garden. This has worked fine for over a year when sudenly my broadb...
DarrenM
Dec 06, 2016Sr. NETGEAR Moderator
Hello ENsa53
It could be either the extender or the router try changing the wireless channel on the router see if it will still crash. You also may want to setup the extender again by doing a factory reset.
DarrenM
Ensa53
Dec 07, 2016Aspirant
Thanks DarrenM
If I understand correctly my BT Hub channel is set on automatic so should change itself if problems are detected or Hub is reset. I have also read that the hub will reboot if problems are detected and that is probably what is happening. I had already tried a factory reset of the extender and Hub to no avail. However in the mean time BT have sent me a replacement router, this also crashed at first but then I seperated the 2.4 GHz and 5 GHz channels on the router by assighning seperate SSIDs, reset the extender again and 'voila' everything started working. It has been working for over 12Hrs now but still not really sure what caused it, possibly a faulty router, but not totally convinced. Thanks again for your help.
Ensa53
