TearMilo's avatar
TearMilo
Follower
Mar 07, 2016
EX6100 WIFI RANGE EXTENDER WRONG PASSWORD
HI...
I try to connect the extender with the WPS, it does shows the new extender's wireless networks on my wifi lists but whenever i type in my original password as i used for my wifi router and it keeps showing that the password is incorrect or password is invalid. I have double checked with the password and it's the right one.
Could you explain why or how should i get it right?
Tear
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Hello Tear
    Have you tried to factory reset the ex6100 and then try to connect agian?
    DarrenM
    • FrustratedEX610's avatar
      FrustratedEX610
      A Factory reset is an arduous process requiring setting up the extender again from scratch, no?  And how might we accomplish the reset if we cannot connect?  What is the hardware process?  How about some actual help here?!?
      In my case, I'm not using WPS.  My Model EX6100 extender has a solid green light connection to router, but even after rebooting the iPad (iOS 9.3) and the extender (current firmware) it keeps reporting "incorrect password." I know for certain that my password is correct. This problem occurred after I was connected and used the web interface to change the extender security from WPA+WPA2 AES to just plain WPA2. This is the case for both bands (2.4 GHz & 5 GHz). And yes, the iPad is set to WPA2 as well. So it seems to have something to do with the designation of the security protocol.
      Please help.
      • DarrenM's avatar
        DarrenM
        Hello FrustratedEx610
        To do a Factory reset you hold down the reset button on the extender for 10 seconds it should be a small pin hole on the device that your will need a pen or paper clip to push this will reset it to default and then let you connect to the device to set it up and obtain the password.
        DarrenM
  • I'm still having problem. I read in one thread that reverting to the prior firmware version resolves the issue. How do I do that?
    Your EX6100 product doesn't work with iOS devices. I'm about to ask for a refund. All my iOS devices connect fine directly to the wifi router when close enough for reception.
  • In some cases a connection can be made, but it gets dropped. Then it commences asking for the PE, and reporting the same wrong PW error or could not connect error.
    This is maddening.
    • DarrenM's avatar
      DarrenM
      Have you made sure that your extenders network name is different from the main routers?
      DarrenM
  • DarrenM's avatar
    DarrenM
    The other thing I would suggest is to make sure it is using wpa2 security and is on the latest firmware.
    DarrenM
      FrustratedEX610
      Darren,
      Firmware is reported as "up to date", V1.0.2.16_1.1.130
      Concerning security type: It was WPA2-only until yesterday when I switched to WPA2-PSK [TKIP] + WPA2-PSK [AES], which seemed to help somewhat. Can't be sure though connections seem to be holding so far. I don't need super high speeds. I don't watch high definition video over the internet.
