nberry11
Dec 03, 2017Follower
EX6100 won't connect
i have a Netgear EX6100 wifi extender that was accidentally unplugged and now has stopped working.
When I power it up the "left arrow" LED which points toward the Router Link LED will briefly flicker blue (normal operation is green) but that's all it will do. Doesn't seem like it will connect to anything, none of the other LEDs light up either.
1 Reply
- DarrenMSr. NETGEAR Moderator
Have you tried to factory reset the extender by holding the reset button for 10 + seconds then setup the extender again.
DarrenM
DarrenM
