Blair55
Apr 04, 2015Aspirant
EX6100 won't work with LG TV
I bought a Netgear EX6100 extender and it works well with everything except an LG 47LV5500-UA TV. I get the error message “Failed to connect to network. Check if DHCP is set in gateway. IF DHCP is not...
Babylon5
Apr 05, 2015NETGEAR Employee Retired
Have you tried setting IP data manually at the TV? Error messages given by devices like TVs are often simplistic or misleading, they will for example comment about DHCP even though they have not made a basic wireless connection to the network, i.e. they will complain about a symptom rather than the cause. So if you set IP data manually at the TV and you still don’t get a connection then the problem is likely to be something other than DHCP.
