Whyzgi
Sep 19, 2016Aspirant
EX6100
Hello eveyone, I recently purchased this item and set it up just as anextender, but it seems to have trouble staying connected to the main router. If I switch this router in to AP mode will I still be able to use the remaining 4 ethernet ports in the back as a switch. Or would I have to run a wire from a switch to the extender for the AP mode.
The instructions say that when in ap more you can only connect to it through wifi and the other ports become useless, but from what I read on amazon after the firmware is up to date I can use it as a AP and the other 4 as a switch.
I am Just looking for some clerity on the matter.
Thanks in advance for any help that can be given.
- DarrenMSr. NETGEAR Moderator
Hello Whyzgi
To use it in AP mode you would have to connect it via Ethernet and it would take up a port to do so. But if you are having issues with it staying connected via wireless I would suggest trying to adjust the wireless channel on you main router.
DarrenM
