Hansom
Sep 06, 2018Follower
EX6100v2 Signal dropping constantly
I have a Netgear wifi range extender model EX6100v2 and the signal drops all the time. The problem doesnt seem to be with my router, distance, or anything of that sort because I have a Linksys wifi a...
DexterJB
Sep 10, 2018NETGEAR Moderator
Hi Hansom,
Welcome to the community!
1. What is the firmware version of the extender?
2. When you say "the signal drops", do you lose the SSID/WiFi signal or just just the Internet access?
3. Have you tried changing the wireless channel?
4. What is the status of he router link LED when it drops?
5. Have you tried resetting the extender?
Dexter
Community Team
DexterJB
Sep 16, 2018NETGEAR Moderator
Hi Hansom,
I would like to follow up and check if you are still experiencing the issue.
Dexter
Community Team
- GJHolmesOct 02, 2018Tutor
I am having the same issue. I have two EX6100/AC750 range extenders one at home and one at my work place. They are both set up as access points and both drop the wifi signal frequently. I am connected to the wifi on my Mac Book Pro. All frimware is up to date. Looking for a solution please.
