Hansom
Sep 06, 2018Follower
EX6100v2 Signal dropping constantly
I have a Netgear wifi range extender model EX6100v2 and the signal drops all the time. The problem doesnt seem to be with my router, distance, or anything of that sort because I have a Linksys wifi a...
DexterJB
Sep 16, 2018NETGEAR Moderator
Hi Hansom,
I would like to follow up and check if you are still experiencing the issue.
Dexter
Community Team
GJHolmes
Oct 02, 2018Tutor
I am having the same issue. I have two EX6100/AC750 range extenders one at home and one at my work place. They are both set up as access points and both drop the wifi signal frequently. I am connected to the wifi on my Mac Book Pro. All frimware is up to date. Looking for a solution please.
