evpq's avatar
evpq
Follower
Jul 30, 2022
EX6100v2 Unable to connect to the extender's network
GreetingsI  I have a Netgear extender model EX6100v2 that had been working fine until a recent power outage in my neighborhood.  Since that time the extender no longer works.  I've tried the factory reset option and am able to get a solid green power light but I am unable to see the netgear.exe wifi to connect the extender to my network.  I'm on Verizon's FIOS network and the network itself is fine.
Any assistance will be greatly appreciated!
1 Reply
  • plemans's avatar
    That device has an ethernet port on it.
    Can you hardwire in a pc/laptop to it and attempt setup that route? (just make sure to disable wifi on the pc/laptop you use so it doesn't default back to that connection)
