leegodbear's avatar
leegodbear
Follower
Aug 21, 2020
EX6110 Connection Issue
This extender is driving me craxzy.  Before I put a hammer to it I thought I'd try the support forum.
I cant tell you how many times I've reset it, updated the firmware, etc.  I go through the connection setup, and all goes ok, but ALWAYS eventually it stops having a connection to the internet.  The lights remain on but it just wont connect.  This sometimes happens shortly after setup, sometimes a few days.
It happened in my old house with different router, I eventually bought a better extender.  I now have a second home so thought I'd try again with EX6110 considering its a different house, different router, etc.....exactly the same issues.
Shall I take a hammer to it or can somebody perhaps help me through troubleshooting thats not just off/on, reset, or redo setup?!
1 Reply
  • plemans's avatar
    Firmware update isn't always the best option.
    A couple things to try.
    1. Don't install via wps. Use the installation assistant.
    2. actualy try downgrading the firmware. after the downgrade, factory reset, then reinstall.
    3. try setting a static ip address in your router for the extender.
