nigh3500
Sep 08, 2018Aspirant
EX6110 registration
The model above is actually EX6110/AC1200 WiFi range extender but that does not appear in the drop-down list.
Firstly, I can't register the device in order to use the 90 day support. I've registere...
nigh3500
I don't think it has been registered, why would that have been done using my e-mail address? It came sealed in it's box from a major UK company (Argos).
I tried the reset using the recessed button on the side, no difference.
Sep 12, 2018Guru - Experienced User
Log into my.netgear.com, and see if the 6110 is listed in your registered product list. If it isn't, then try using the "register a product" link on https://www.netgear.com/mynetgear/portal/myProducts.aspx
I am wondering if you were trying to create a new account before.
