GrahamTate
Oct 12, 2020Follower
EX6110 won't produce extender network NETGEAR_EXT
Following instructions, using installation assistant, paragragh 1 states that upon plugging in the range extender near to the Hub two green LEDs will glow.
That happens but the next step, opening WIFI manager on a smart phone does not show any extended network NETGEAR_EXT.
did you try factory resetting it?
Push and hold reset for 7-15 seconds while its powered on?
1 Reply
