KasKelly's avatar
Jul 20, 2021
EX6120 connecting to a WiFi Antenna
I have a wirreless router in the house and need to get WiFi signal into the detached garage.  Problem is our garage is  - double wall steel  w/ insulation in the middle.  Nothing get through!!  I purchase theNetgear EX6120 - AC1200 dual band WiFi extender.  Still had the problem of getting the signal into the garage in order for the extender to work.  I then purchased a WiFi Antenna (Tupavco - Model TP542)  Got that mounted and hardwired to the extender.  Still no signal.  What am I doing wrong?
  • plemans's avatar
    what you're doing wrong is trying to get a signal through steel. double walled at that.
    Its one of the top blockers of wifi.
    Options?
    1. drill through it and run ethernet out to the garage
    2. use powerline adapters to get out to the garage
    3. use moca adapters (ethernet over coax)
    You can keep trying at getting a signal through it but it isn't an issue of the devices but an issue of wifi doesn't broadcast through steel
    • KasKelly's avatar
      KasKelly
      Tutor
      Correct - about trying to go through steel.  That is why I got the WiFi antenna.  It is mounted on the outside of the garage and the hardwire goes into the garage and plugged into the extender.  The antenna is actually line in site of the wireless in the house.  So it should have a very good signal.
      • plemans's avatar
        so the Extender is in the garage with the antenna in the home? (going through the wall)
        It'd mean there isn't any antenna's in the garage to broacast. If you hardwire a pc/laptop into the extender, does it work? It'd also let you check the connection back to the router.
