BamaDawg
Sep 19, 2018Aspirant
ex6120-Does not connect to laptop the ethernet port and will not download firmware update
I have an EX6120 range extender that when connected by ethernet cable to my laptop, doesnt work properly. It worked fine after setup and then shut laptop down, doesnt work properly at all. Takes fo...
BamaDawg
I can use chrome fine for netgear.com. It has an issue when using chrome for mywifiext.net. The screen just blinks. Never done that before. Go to edge and it opens up just fine. When i download the file through chrome manually, I see it download to a zip file, I open it and thers nothing but a chk. file and instructions. Nothing else. No executable, nothing. Ive updated these things before and it downloads and updates automatically but not this extender. While using my phone, laptop, or wifes tablet, it works fine except it its about half the speed it was running at. about 45mbs to about 20-22mbs. Going back to the firmware upgrade, no matter what I do, on mywifiext.net, it says that im not connected to the internet, which I am lol. Its never done that on updrades before. I've reset this extender so many times that my fingers hurt. I would also like to be able to use my ethernet again because for some reason it runs at about 100mbs when it worked now nothing.
Sep 19, 2018Guru - Experienced User
Ok. That suggests there an browser compatibility issue in the extender's web pages. Possibly updating the firmware will fix that.
And that is all you need. The chk file is the new firmware. You don't open the chk on the PC, instead you upload it using the browse control on the firmware update page in mywifiext.net After the chk file is uploaded, the extender checks it to make sure it is valid and installs it (requiring a reboot). See page 40-41 of your manual ( http://www.downloads.netgear.com/files/GDC/EX6120/EX6120_UM_25Aug2015.pdf )
The "check online" function on that page should also have worked though.
- BamaDawgSep 20, 2018Aspirant
Got the firmware upgrade to go through using edge after about 30 tries. And that was today alone. It still took roughly about 5 reboots before I finally got the ethernet port to work because that was my main concern. Even after the upgrade, I still can't load mywifiext.net into the web browser of Chrome. It's just stutters or blink when you hit search. Just for giggles I've even made sure Java was up to date but it still just blinks. It's amazing how just checking on a simple update because my ethernet port stopped working on my extender, has turned into this lol.
