Glenn88
Nov 25, 2017Aspirant
EX6120 green blinking power light
I installed the extender and set up my network. After that process, I was asked if I wanted to update the firmware. I had to step away for a few minutes after that started. Afterwards, I saw only ...
- Nov 29, 2017
You could try to reflash the firmware via TFTP I linked below how to do this.
https://kb.netgear.com/22688/How-to-upload-firmware-to-a-NETGEAR-router-using-TFTP
DarrenM
DarrenM
Nov 29, 2017Sr. NETGEAR Moderator
DarrenM
- Glenn88Nov 30, 2017Aspirant
Thanks. It took me two tries to get the settings correct but it updated the firmware and works like new. The first trial I may not have waited long enough for the setup.
Dual Band WiFi Range Extender / EX6120
Firmware: V1.0.0.32_1.0.21
