Glenn88
Nov 25, 2017Aspirant
EX6120 green blinking power light
I installed the extender and set up my network. After that process, I was asked if I wanted to update the firmware. I had to step away for a few minutes after that started. Afterwards, I saw only ...
- Nov 29, 2017
You could try to reflash the firmware via TFTP I linked below how to do this.
https://kb.netgear.com/22688/How-to-upload-firmware-to-a-NETGEAR-router-using-TFTP
DarrenM
DarrenM
Nov 29, 2017Sr. NETGEAR Moderator
DarrenM
Glenn88
Nov 30, 2017Aspirant
Thanks. It took me two tries to get the settings correct but it updated the firmware and works like new. The first trial I may not have waited long enough for the setup.
Dual Band WiFi Range Extender / EX6120
Firmware: V1.0.0.32_1.0.21
