NiKRuLeZ
Jul 25, 2025Tutor
EX6120 in Bridge Mode – Should Backhaul Be Connected to Both Bands or Just One?
Hi all, I’m using the Netgear EX6120 purely as a Wi-Fi-to-Ethernet bridge, and I’m hoping to clarify the best way to configure the backhaul connection in this mode. 🔧 My Setup: The EX6120 ...
Jul 25, 2025Guru - Experienced User
First off. Disabling the "radios" doesn't. If they were disabled, it couldn't connect back to the router. You just disabled the ssid broadcast. It doesn't impact performance or stop the actual wifi from broadcasting. Not much use to do other than looks nicer from a standard scanner.
Next. Even though the 2.4ghz is showing a better signal it doesn't mean its faster. 2.4ghz is a slow network and sensitive to interference. Its really slow. Test the speed on the hardwired device with each band to see what one actually provides the higher throughput.
IF it was me, I'd use the 5ghz. Much less interference. Tends to be much faster unless its at the very edge of its range. So a little testing is in your best bet.
I'd also probably leave the ssid's broadcasting. Disabling them doesn't change anything other than your thoughts on it so you might as well have them broadcasting in case you want to put a few devices (like IoT devices) on the extender.
- NiKRuLeZJul 25, 2025Tutor
Thanks for the reply...
I've used the scanner software to see if the rebroadcast (for the extender) shows up and it doesn't (not even in hidden SSID) and that's exactly what I want. I only want the ethernet device to connect over the wifi to the main router, I have no need for the actual extender functionality.
The question is, after testing if one band works out better than the other, should I leave both bands connected or purely setup only the best band connection only (either 2.4 or 5ghz)? Theres a radio button that says:- Ethernet ports to WiFi use the following band: 2.4GHz 5GHz (when both bands are connected to the router)
So I think I can choose which backhaul band to use back to the main router.
Let me know!
