dlwmacgregor's avatar
dlwmacgregor
Follower
Dec 25, 2025
EX6120 Network Names
I have 2 EX6120 Extenders.
What would the extended network names be for both.
I can see SSID_2GEXT and SSID_5GEXT but only one entry for each one.
But I have 2 units.
Should I not be seeing 4 entries?
Thanks
Doug
  • StephenB's avatar
    Unplug one extender, then log into the web ui of the other (while connected to the extender's wifi network).  Change the name of the WiFi network on it.  Instructions are on page 21 of the manual.
    Then power up the second extender and do that again.
  • FURRYe38's avatar
    You would on a wifi analyzer however having two will show the same on a mobile device like a phone or pad.
    You could let the extenders connect and then select use same SSID name network for the output of each coming from the main host wifi router signal.
