May 05, 2022Guru - Experienced User
What security are you using? WPA2 is standard.
there's a newer wpa3 standard but you'd have to upgrade hardware to get that.
And apple devices are great at giving you a notice that "your security is weak" when you're not on the latest devices.
Quite a few devices still use wpa2 perfectly fine.
