Googolplex's avatar
Googolplex
Follower
Jun 11, 2016
EX6120 vs. EX6150
Hi.
I am looking to buy one of the following Wifi-extenders. However I cannot find any differences between the two models:
EX6120
EX6150
Except that one is bigger than the other one ofc.
Can anyone tell me what the differences are?
  • So the main differences are  that the
    6150 has a slightly more powerful CPU
    With that CPU power it can now do Simultaneous dual band WiFi, which the 6120 cant
    It also has a Gigabit (10/100/1000) ethernet port vs the 6120 having aa FastEthernet(10/100)
    The 6150 also has an ability to switch to Access Point Mode (is done via physical switch)
    The last bit is the 6150 has an extra Physical button of WPS button
    hope that helps
1 Reply
    hope that helps
