Mchamb70
Jul 13, 2017Aspirant
EX6120 WIFI Range Extender not connecting to the 5GHZ signal from my Pace AT&T 5268AC Router
I am able to connect to the router on 2.4GHZ but am having no luck connecting it to 5GHZ.. It is able to see it on initial set up but after that no luck. Your session will time out in one minute...
DarrenM
Jul 19, 2017Sr. NETGEAR Moderator
Did you set up the extender beside the router and then move it to the location you are needing it in?
DarrenM
- Mchamb70Jul 19, 2017AspirantYes, within 3 feet of it.
- mhackneySep 15, 2017Aspirant
I am having exactly the same issue on an EX6120 I bought today. Same firmware version, all stats you show are the same. I have a FIOS router and every device in my house can connect on either the 2.4 or 5GHz networks I have configured.
I think I'll just send this back to Amazon, not worth the headache.
- KurtAOct 18, 2017Initiate
Same Problem here.
I Send it back to Amazon.
