Francis79's avatar
Apr 29, 2024
Ex6120
After a change of router, a factory reset to the 6120 and re-setup the 2.4Gz band is working OK, but the 5Gz is broadcasting but I cannot connect any devices to it that were previously connected. Unable to login to the 6120 after a fware upgrade browser does not support the protocol it is now using. Have tried different browsers no good. Any ideas?
  • plemans's avatar
    1. what router did you connect it to?
    2. what method of setup did you use? WPS, the installation assistant, the app?
    3. a screensnip of the browser error you get might help
    4. are you able to access the extender using the IP address the router assigns it?
    5. What channel is the 5ghz using on the router?
    • Francis79's avatar
      Francis79
      Tutor
      Vodafone router
      Setup via gui, wps didnt work
      Message read 'This site can’t provide a secure connection as the requested website uses an unsupported protocol.'
      Unable to access via ip address same message
      Not sure of 5ghz channel
      Regards
