Hamster244
Mar 15, 2018Aspirant
Ex6150 Ac1200 access point disconnecting
Hi here I have purchased the ex6150 WiFi extender as I have a virgin media superhub but the location isn't great for signal, at first I was using this as a WiFi extender, however this would drop out o...
Hamster244
Hi there, just followed your instructions rebooted to factory, changed firmware and set it up again, and once again after around 30 min i disconnected, so i tried updating the firmware again to the newest since setting it up anew again and same story unfortunately,
Is there anything else I can try?
jvasanth1984
Mar 15, 2018Virtuoso
Hi Hamster244,
Did you tried reset by holding paper clip in reset hole and reconfigured it? if yes, try ON/OFF reset which is like rebooting extender during reset process. You have to hold reset button and keep turning OFF and turning ON the extender for ever 10 seconds Once its done, reconfigure it and see if issue persist. If yes, call Netgear support.
