SteinarGrande
Nov 16, 2015Tutor
EX6150 disconnect clients after a time period.
After installing two separate EX6150 as AP (access points) they both disconnect Wi-Fi devices/clients, which are wall mounted and steadily fix’ed. This behavior are observed after apparently one or...
nhann
Nov 16, 2015NETGEAR Employee Retired
Hi SteinarGrande,
Can you please confirm the firmware version on the EX6150 and which router is connected to it?
- SteinarGrandeNov 16, 2015Tutor
The Netgear support web page state there is one (1), fw, the initial. The router is irrelevant.
- nhannNov 17, 2015NETGEAR Employee Retired
Hi SteinarGrande,
You can try re-flashing the initial firmware onto the EX6150. Download the zip from the support page, unzip the .chk file and manually upload it to your EX6150.
See page 42 of 50: http://www.downloads.netgear.com/files/GDC/EX6150/EX6150_UM_7apr2015.pdf
Also try changing to WiFi channels that are less crowded, on the EX6150.
If you are still experiencing issues, please open a case with Support:
- SteinarGrandeNov 17, 2015Tutor
it's already done, no solutions
