maxpowerwarden
Dec 21, 2018Aspirant
EX6150/AC1200 WiFi range extender NO INTERNET
No internet connection. I used the extender for months with no issue and now there is no internet connection. I have factory reset multiple times and changed SSID. Please help :)
- Dec 26, 2018
I figured out how to upgrade the firmware and performed a factory reset. I ran through the setup and exactly the same thing happens. Connects to extender but NO INTERNET connection. I attached a shot to show the firmware update has been completed.
Christian_R
Dec 21, 2018NETGEAR Employee Retired
Hello maxpowerwarden,
1. What FW version is your extender on?
2. What devices are having issues connecting to the extender?
3. Are devices able to connect to the router/modem?
~Christian
- maxpowerwardenDec 22, 2018AspirantHi Christian,
Not sure about the firewall but I have no issues, at all, with my laptop on Windows XP and my Samsung Note 8 connecting through the wireless router.
I attached a screenshot of the available networks. The one to which I am connected works perfectly and the two newly created extender networks will not connect to the internet.
Cheers,
Roscoe- StephenBDec 23, 2018Guru - Experienced User
maxpowerwarden wrote:
Not sure about the firewall ..."FW" meant "firmware".
When you connect to the extender networks, can you reach www.mywifiext.net? That isn't on the internet, it is the extender's management web interface.
If you can, please post the screen that shows the extender status and the firmware version.
- maxpowerwardenDec 25, 2018AspirantAttached photo. Cheers
