maxpowerwarden
Dec 21, 2018Aspirant
EX6150/AC1200 WiFi range extender NO INTERNET
No internet connection. I used the extender for months with no issue and now there is no internet connection. I have factory reset multiple times and changed SSID. Please help :)
- Dec 26, 2018
I figured out how to upgrade the firmware and performed a factory reset. I ran through the setup and exactly the same thing happens. Connects to extender but NO INTERNET connection. I attached a shot to show the firmware update has been completed.
maxpowerwarden
Dec 26, 2018Aspirant
Are you kidding me!
The video to download the new firmware requires I connect to the internet through the extender... which is exactly what I have been trying to do, unsuccessfully, for weeks! I cannot connect to internet so I cnnot obviously download the new firmware which is what you are asking me to do...
maxpowerwarden
- StephenBDec 27, 2018Guru - Experienced User
Try resetting one more time, and this time don't press the WPS on the EX6150.
You'll see a network called NETGEAR_EXT. Join that network, and then browse to www.mywifiext.net. Then follow the Connect with Web Browser Setup section of the manual (page 11 here: http://www.downloads.netgear.com/files/GDC/EX6150/EX6150_UM_EN.pdf )
- androideJan 12, 2019Aspirant
I have the same problem, it started after the last security upgrade. I've had the AC1200 for a two or three years working fine. After the last firmware upgrade, maybe ocober / november last year, I have no internet. I have reset it several times, changed places, nothing.
I thought reseting to factory default would correct the isuue, nothing.
I can connect to the extender, have all five lines, the light in the extender is green, but nothing.
Any ideas, besides getting a new one?
