taikhau
Feb 15, 2018Aspirant
EX6150/AC1200 WiFi range extender, wont connect to WPS
I can't seem to connect my extender to the wifi. I am trying to do this with the extender in the same room. I have factory resetted it just in case and tried connecting it via WPS and manually throug...
jvasanth1984
Feb 16, 2018Virtuoso
Hi taikhau,
WPS may not work if wireless security on your main router is WEP or WPS was disabled on it. When you attempt web browser method, what error are you getting so that I can guide you with right steps.
