taikhau
Feb 15, 2018Aspirant
EX6150/AC1200 WiFi range extender, wont connect to WPS
I can't seem to connect my extender to the wifi. I am trying to do this with the extender in the same room. I have factory resetted it just in case and tried connecting it via WPS and manually throug...
jvasanth1984
Feb 16, 2018Virtuoso
Hi taikhau,
WPS may not work if wireless security on your main router is WEP or WPS was disabled on it. When you attempt web browser method, what error are you getting so that I can guide you with right steps.
taikhau
Mar 02, 2018Aspirant
Step 7 in the manual says to select a WiFi netowrk to extend. This is where I cannot continue as neither of my Wifi networks are showing up but I can see my neighbours wifi networks on the list.
- jvasanth1984Mar 04, 2018Virtuoso
Hi taikhau,
Please check for your wireless network name_EXT in available list and get connected to it with same password as your wireless network.
