kencpo
Dec 05, 2017Aspirant
EX6150/AC1200 WiFi range extender
Everything was working great after I set it up theEX6150/AC1200 WiFi range extender. via WPS button on my router. This was 2 months ago. All of I sudden I can only connect with 5G. 2G connects for ...
- Dec 08, 2017
Have you tried the fastlane settings and make the extender only broadcast the 2.4ghz?
DarrenM
DarrenM
Dec 08, 2017Sr. NETGEAR Moderator
DarrenM
kencpo
Dec 09, 2017Aspirant
Thanks. Problem seems to be solved. There was an update when I opened www.mywifiext.net. I unchecked 5Gbut I still can connect with 5G I can even toggle between the 2 bands.
