semola1
Jan 29, 2018Tutor
EX6150/AC1200 WiFi range extender
Hi All, I have a little problem with my Ex6150 Range extender. I have configured it creating 2 new SSID (adding a "_1" to router original SSID name). In total I have 4 SSID (2 for 2,4Ghz and 2 for ...
semola1
Feb 18, 2018Tutor
I'm updated the firware with last version (V1.0.0.34_1.0.69) about two weeks ago, but the problem is still there.
Marcello
jvasanth1984
Feb 18, 2018Virtuoso
Hi semola1,
Try to reset and reconfigure the extender to see if you still witness the issue.
- semola1Feb 19, 2018Tutor
I tried to reconfigure the extender, but the problem persists. I found this with the wireless connection of a Raspberry PI.
Is it possible that it depends on the PI? If yes, then it is not a problem, I will finish the configuration via cable.I tried to reconfigure the extender, but the problem persists. I found this with the wireless connection of a Raspberry PI.
Is it possible that it depends on the PI? If yes, then it is not a problem, I will finish the configuration via cable.Thanks
- jvasanth1984Feb 21, 2018Virtuoso
Hi semola1,
I would recommend you to complete the setup with cable and check.
