PQALZM's avatar
PQALZM
EX6150/AC1200 WiFi Range Extender
Hi
Just received this today and initial set-up has been very straight forward.
However, ideally I'd like the extender to work by replicating the network so that devices will connect seemlessly as they move around the property.  So far I can only see it setting up with a different network name and thus it will require a manual movement from one network to the other - unless of course the device loses connectivity completely to the main network.
Does anyone know if it is possible to set this device up to replicate the network and allow a seemless change for devices as they move around and the signal from the main router becomes weak?
