timothybarrier7
Dec 15, 2018Aspirant
EX6150V2 / AC1200
Have gotten all the way to "Log into new EXT network with whatever devices with wifi you want"
When I go to sign in, all I get is "Can't connect to this network"
Ive factory reset, been o...
Dec 16, 2018Guru - Experienced User
If you used the WPS setup, the network should use the same password as your router network.
Have you tried that?
- timothybarrier7Dec 16, 2018AspirantYes. Everything has setup properly I believe I've even got the Netgear genie app showing me that everything is hooked up it's just when I go to sign on to the actual site for the extender it says internet is not available. It's mind-boggling to me the only thing I can think of is the MAC address and what not is not in my router but every time I go to get in my router that's through spectrum Askey model I can't sign in tells me unavailable the site
- StephenBDec 16, 2018Guru - Experienced User
Are you connecting to the extender network when you browse to www.mywifiext.net?
- timothybarrier7Dec 16, 2018AspirantYeah.... I'm all the way to this point hopefully this photo shows you what I'm referring to... I have the extender hook to the network here at my home but I can't get connection out of it when I try to use my cell phone or pad all it says internet may not be available and then I have to sign back over to my home network
